- 1 Dec 2008
Alright, i'm no expert on watercooling at all, infact i have no idea of the requirments needed to cool components, but i was thinking bout how to make a dual loop inside my case, and although theres plenty of room, its not very versatile when it comes to fitting radiators,
Ok! so i have a thermaltake VH6000BWS
If i remove the HDD cage, i can fit a 120mm Rad and 2 fans in push/pull config for the first radiator, this would be over the intake fan
And i already know i can fit the same fan/rad config on the back - rear vent
But would a single 120mm rad for each loop, be sufficient to cool an AMD 9950 CPU on 1 loop, and an ATI 4870 on the 2nd?
