Can anyone decode the following regarding the dual M2 setup on an Asrock H570M-ITX/ac:
- 1 x Hyper M.2 Socket (M2_1), supports M Key type 2280 M.2 PCI Express module up to Gen4x4 (64 Gb/s) (Only supported with 11th Gen Intel® Core™ Processors)*
- 1 x Ultra M.2 Socket (M2_2), supports M Key type 2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
*Supports Intel® Optane™ Technology
Supports NVMe SSD as boot disks
Supports ASRock U.2 Kit
If I purchase an Intel i9-10850k will both M2 Slots work (of course at PCIE Gen 3 x4 speeds)??
Also, would having a Z590 motherboard be better in respect that it has 24 PCIE lanes as opposed to the 20 PCIE lanes on the H570M motherboard?
The reason I ask, is that I have two WD Black SN750 NVME PCIE storage devices, one is 500gb and the other is 1TB, and eventually (sometime in the long future it seems), I will purchase a RTX3080. As the Asrock website and manual doesn't give much in the way of diagrams, I'm just trying to work out if the 24 PCIE lanes will be better for running 2 x NVME PCIE devices along with the RTX3080 or the 20 PCIE lanes will be enough.
Im not into overclocking, but seeing as there doesn't seem to be a i9-10850 cpu, im happy to take the K version anyway, hence why I am looking at the H570 over the Z590.
