Dual monitor advice
28 Dec 2011
Hello,
I have just purchased the Acer
G276HL 27" 1920x1080 TN Widescreen LED Zeroframe Monitor - Black, and I am currently running an old 22" benq monitor I want to keep my old one as a second monitor.
I have looked and if connecting two monitors its recommended using the same connections. my old one only supports dvi-d not hdmi or display ports. should I connect the new one using dvi-d or a different connection?
I will likely just use the 22" for YouTube or something whilst gaming on the bigger one due to the size difference. so will it matter how I connect them?
Thanks
