Dual monitor arm which sits flush against wall?
Mobster
9 Apr 2012
I have two Dell 24 inch monitors with a dual monitor mount that screws to the desk. It's good except the monitors extend a long way out from the wall because the mount runs into the wall.
The way I have my monitors oriented is that they are bent in so that where they meet in the middle is closer to the wall than the outside (if that makes sense).
Is there something I can buy/do which will allow me to orient them this way but be very close to the wall?
Although on a single UW monitor, I have a shallow desk and had a similar dilema with most arms resulting in the monitor standing a long way from the wall. Ended up changing to the now hard-to-find Duronic DM12X1. Whilst looking into that came across the Kensington smartfit dual monitor arm (part no K55513WW). Might be worth a look, although it only alows a small amount of swivel.
