dual monitor help
16 Feb 2006
yo.
im running two crts, one at 19" and one 17".
i have the 19 at 16x12 and the 17 at a slighty lower res (cant remeber what 12x10 i think).
now since having them like this i have been unable to get the settings correct on the 17", all the windows look warped and outta shape, now if i mess with the settings on it i still cant get it to look correct. is this to do with running them at different res's or is it something else?
dreadi
isnt they any buttons on the screen you can play around with?? my old BIG crt had the same problem, played with them, worked fine :)
