Dual Monitor in Ubiuntu
19 Oct 2002
Swindoniantown
I installed Ubuntu on my Laptop (spec in Sig) and all was fine, love Ubuntu its got a nice feel to it compared to most Linux Distros I've used.
Only one Problem I found!...
I can't get it to Dual Monitor the 16" Laptop display and the 22" HD screen I mainly use!!..
It will only show the 16" Laptop Display.
I tried following a work around I found on the google!, but this only fudged the install and it wouldn't get to the Login screen!..
Anyone with a Laptop with nVidia Graphics got a Dual Screen system working on Ubuntu??
Any help much appreciated!! :)
Definitely got nvidia drivers installed? run "nvidia-settings" from command line, and check you have the 2nd monitor enabled. As its a laptop you might need to do the daft "function + (X)" key sequence, to get the monitor working (same as how you would in windoze).
