Dual Monitor issue
11 Feb 2009
Barnsley, South Yorkshire
I recently got a BenQ GL2460 yesterday, plugged it in and everything works fine across both monitors. When I turned my PC on today there is a black bar going down the right side of the GL2460, it's like the display is cutting off at that point.
When I turn on the monitor normally and it comes up with the monitor boot message it displays that perfectly across the entire monitor.
Here is a small picture better explaining my problem:
http://imgur.com/Ig8PttO
I've restarted the PC etc. Unplugged the monitor and reset the settings on the display as well. When I change res. in windows it puts it back to the full display size but then auto adjusts it back to the above.
That option doesn't seem to be present in Catalyst Control Center anymore :/
I've been able to "fix" the issue by moving the monitor in CCC and on the displays options as well, but I ideally want to know the proper fix if there is one.
