- 30 Nov 2010
- UK
*Ignore got it working with a driver 2 versions older.
I've been using dual/triple monitors for years without issues. I have recently swapped my 680 for a 980Ti and not had any issues until now I want to add my second monitor.
I have my 1440 primary display using displayport-display port cable and this works fine on it's own. My 1080 monitor using a hdmi-hdmi cable and that works fine on it's own.
If I have my 1440 on and set to primary and then go to enable my 1080 monitor in the Nvidia control panel by ticking the enable box and pressing apply a second later the window flashes and come back un-ticked. If I do it the opposite way so the 1080 as primary and enable the 1440 it works but the 1440 is very blurry yet it still shows 2560x1440 as the resolution.
Any ideas?
Using Win 10 and the 1440 is a Dell U2711 and the other is a Asus VE247H.
Also tried reinstalling the latest driver 358.91
*Edit* I was using this exact setup (same cable's and montors) just a few weeks ago. I also thought I had everything working with the new card but it was a few weeks ago and can't be sure.
Any ideas?
