Dual monitor max resolution on an H67 motherboard.
12 Jan 2011
While researching the spec sheets for some new H67 Sandybridge motherboards I have been able to extract info on the max resolution on the various fitted DVI, HDMI and Display Port outputs. However is it safe to assume these max resolutions are available when a motherboard is connected to dual monitors? For clarification the integrated Sandybridge HD3000 GPU will be driving this.
My base requirement would be for a 1920 x 1200 central display with my existing 1600 x 1200 screen demoted to a portrait aspect second display.
