dual monitor mount?
11 Aug 2015
Hi all
I'm looking for a dual monitor mount that sits flush to the wall. I cannot seem to find anything that's suitable, which makes me think I'm asking for somethingh that's not possible....
Hopefully you're able to help. One monitor is 32" the other is 27".
Many thanks
Be wary about the weight of your monitors. I've bought 3 different mounts (All relatively cheap on ones) that said they could take the weight of my monitor but all drooped (My monitor is quite heavy)
If you want flush to the wall, why not Vesa brackets?
I hadnt heard of these - thank you. Ordered some off the Rainforest, will see what they're like.
Many thanks
Edit: They're perfect! Thank you so much for suggesting them as they're brilliant.
