Dual monitor problem! URGENT!
20 Oct 2004
Hi guys
Big problem - just switched to dual monitor mode on my girlfriend's laptop to try to get it to output to the LCD TV. Unfortunately the TV isn't recognising the signal (possibly set the res too high) but it's made that the main monitor with the result that I can't change it back!
When I right click on the secondary desktop and go to properties it doesn't open on that desktop - it must be opening on the primary which I can't see!
Any ideas how to undo this mess?
Thanks
Just disconnect the LCD and reboot, it should revert to single monitor mode when it doesn't detect a second monitor.
Make sure to use 60Mhz refresh rate when connecting to an LCD TV.
