Hi guys.
Have just seen a post about someone having problems with their dual monitors but didn't want to invade on there thread so have made another one instead.
Basically I have just bought a new monitor so I now have 2 x Iiyama ProLite E2407's going into my 2 DVI ports on my graphics.
http://www.overclockers.co.uk/showproduct.php?prodid=MO-051-IY&groupid=17&catid=510&subcat=
Graphics card is a Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express.
The problem is one of the monitors just decides to go off randomly and then when I try and unplug/plug the DVI cable back in, it doesn't have any of it.
Furthermore, through messing round with the DVI cable's the PC has now started to Blue Screen when a monitor is unplugged.
Can't see why it would be doing this.
Any ideas?
Cheers
Tom.
Any ideas?
Cheers
Tom.
