dual monitor problems
30 Aug 2006
Hi i have a dual monitor problem , all my apps opens up on monitor 1 , i have tried using ultramon , but they still open on one , i can move some but not all to monitor 2 , is there anyway i can force an app to use monitor 2 ?
Right click the icon for the app you want to force to open on monitor two, you ahould have an ultramon tab called Ultramon - Window, there you can set screen postion to force to the second screen.
I use ultramon and find if i move a window to the second screen and then close it, next time i open it, it does so on the same screen it was last used on, does this not happen on your's?
Have you extended the desktop to the second monitor, or is it set to dual view/clone mode?
Did you do a Full Ultramon install or custom?
What OS are you running?
