Dual monitor question
6 Dec 2003
Burton on Trent
Sapphire ATI Radeon X1950 Pro 512MB GDDR3 TV-Out/Dual DVI (AGP) - Retail
I want to run 2 monitors, will the above card be ok with my motherboard ASUS P4P800 Deluxe, I know it is AGP but is there any other issues.
Iam not bothered about playing games
Steve :)
yes that'll be fine but if you aren't going to be playing games i'm sure you could probably find a cheaper AGP card with dual outputs.
also depends what u are going to be doing on the dual lcds.
I have dual lcds and i play warcraft and play div x movies on the 2nd lcd.
And this is on a x1900XT so a good card is recommended
Would the card be able to run either a Dell 2007WFP or a 2407WFP, I like both these monitors but not decided on which one yet.
Would I have a problem running one of these alongside my iiyama vision master pro 413, i presume they will run at different resolutions.
Thanks
Yes the card ( i take it you mean the one originally mentioned ) would run either of the Dells , and no there should'nt be a problem running it with your existing monitor.
But as I mentioned and you have now indicated your current monitor is a CRT with I presume only VGA and not DVI there are way cheaper cards with a dvi and vga on rather than dual DVi if and really if games aren't important to you
