Dual Monitor Question
9 Jan 2009
Birmingham, West Midlands
Hello. Was thinking of doing a dual screen setup. Can anyone tell me the best monitors for the job, and wont break the bank? Thinking around £200 for each monitor. Also do i really need a Matrox DualHead2Go since my GFX card already has 2 monitor connections on it?
Thanks.
cant answer 1st question
you do not need a matrox dualhead2go, just connect 1 monitor to each port on the graphics card
Dualhead2Go makes the PC see your 2 monitors as 1 big monitor, rather than 2 separate monitors as only 1 DVI port on the graphics card is used. There are software solutions that will do the same but they dont work well in games but are fine for desktop. If you dont need 1 big screen then any graphics card with 2 DVI/VGA port will do. Any monitor will work, you dont need anything special.
