Dual monitor setup question
16 Sep 2007
Hi, I wonder if someone could help?
I have a 19" Dell flatscreen and 22" Dell widescreen on a dual screen setup. This might seem strange, I know, but I have the 19" set as the primary display and the 22" as the secondary display (for reasons I won't bore you with).
Both monitors are set at their native resolution (19" @ 1280 x 1024 and 22" @ 1680 x 1050 pixels). However, even though the 22" is set as 1680 x 1050 the display window 'mimicks' the 19" so there is a blank border round the edges. Is it possible to have a 19" flatscreen and 22" widescreen as a dual monitor setup without the 22" in effect 'mimicking' the physical size of the 19"?
I hope this make sense.
Any advice would be gratefully appreciated.
Kind regards
Paperback.
Thank you Shine for the reply.
So if I used ultramon, for example, would it enable me to set different monitor setups for different users? i.e. a dual monitor setup for myself (photoshop, etc) and a single monitor setup for other users?
Regards
Paperback
