this is probaly a dumb question but i couldnt really find a straight answer online and this is my first time doing any kind of multi monitor setup so im not really sure how it all works
the main monitor will be for gaming, 1080p 144hz gsync TN panel
the secondary monitor will be for content creation and non gaming media, 1080p 60hz non gsync IPS panel
my question is will it be fine using monitors together that have different refresh rates, gsync and no gsync, different connections (display port for gsync monitor HDMI for IPS monitor) and different panel types TN and IPS or will it be likely to cause issues?
also i was wondering if i would have any in game performance loss from having a second monitor running?
one more silly question, i will be using a SLI graphics setup so do i plug both monitors into 1 GPU or 1 monitor per GPU?
like i said at the start probaly dumb questions but i want to be sure everything is fine before i pull the trigger on this
thanks
thanks
