So, PC is running a monitor for gaming one side of the room via VGA/DVI convertor, but it doubles as a HTPC for the plasma on the other side of the room. This is connected to the AV receiver by the TV via HDMI.
So, even though I'm not using the plasma at the moment, the GPU is still connected, and if I change the AVR to the correct channel it will display.
The question, am I using GPU power for the 'second screen' if you like? Even though I'm not watching it?
