Dual monitor- taskbar question
28 Jan 2015
Ive managed to get both my dell 27”Gsync monitors in windows to single pane-extended view? But the taskbar is showing on the bottom of the second monitor not on the first monitor- 1st is left 2nd is right when facing them
Is it possible to move it to the bottom of 1st monitor or will I have to get used to it
From memory in the display settings you can select which is your primary and that will be the one to get the taskbar on
I have the taskbar on both my Monitors , sorry but cant remember how I did it though, but I'm sure I did it within windows, no need for silly software
No need for software, assuming Windows 10. Just turn it on with taskbar settings.
Also set the primary monitor as the one you want the main pinned icons to appear.
