Dual monitor vertical stand
22 Oct 2008
Lisburn, Northern Ireland
Anyone got a recommendation for a dual monitor arm?
Looking to stack them vertically
27" curved on the top which will be slightly tilted down towards me
34" ultra wide flat screen on the bottom.
I think they are both 100x100 mounts but not 100% sure on the 27" so flexable mounting size would be good.
Not even sure what sort of a budget to have for this, hence this thread :D I bow to your better knowledge.
I prefer the fixed type so there is no wobble, so my choice would be relatively cheap.
I think Duronic do several poles up to 1m in length. Then they do a variety of arms that can fit the pole. They even do a complete dual monitor setup as you describe for £34 (DM35V2X2. Check the forest for that).
