Dual Monitor
28 Feb 2007
Newcastle
I have two monitors setup, is there anyway that u can run say itunes fullscreen without it turning the other monitor black, im modding a case which will have a 5 inch lcd in it and i want to run the album slider in it all the time, thanks for your help.
Im not sure if it will help your problem, but have you downloaded Ultramon yet? Its an essential peice of software for multi screen setups. I don't use I tunes, so I can't really comment on that problem.
ive downloaded the new ultramon for vista but it still doesnt let me the itunes album slider in full screen without turning ther other screen black :( any ideas?
I'm not sure if it can be done, I don't think you can render over both monitors. Well I've never been able to get it to work.
Burnsy
bryanlaycock said:
yeah i gave it ago, but it didnt like vista last time i tryed it :( imprved version not available till next year either :(
There's a v3 Beta out that works with Vista almost flawlessly.
yeah thats the 1 i used, however it doesnt let you run to things in full screen, however, ive thort could you run program in windowed mode (in compatibility? and make it near enuff full screen but not, im away from my pc so i cant try it :( its strange bcos when i play games the other screen doesnt go black? just with itunes :confused:
ive just got home, and theres no choice for windowed mode, i downloaded a new version of itunes and it still does the same, could it be bcos the two screens run two different resolutons?
