Dual Monitor
25 Mar 2011
Problem: The new monitor is at the correct resolution of 1366x768 but the main one has changed to that when it should be 1920x1080.
How do I change one to be 1366x768 and the other to be 1920x1080
The main monitor is now shown as Generic PnP and I cannot change the resolution in the NVidia control panel either.
Regards
I would recommend you find drivers for your monitor listed as Generic Pnp. That should give you the ability to modify it's settings properly.
