dual monitors ? ? ? help ?
24 Jul 2007
Swansea, Wales
i got two monitors, one is a sammy syncmaster 153T and i got a dell 2407.
my graphics card is a Leadtek 8800GTS 640mb. i was wondering if there is any software that i could get to control how the monitors are setup when i put the two screens on one pc
currently i have got them set up as one long monitor. i want to set it so that the two monitors are next to each other but internet explorers dont stretch right across so when i maximise a window it stays within one screen.
Is this possible ?
Thanks
SG
Usually you can set that from the standard driver stuf. Go to the advanced display properties and have a poke around.
I found nVidia's duel screen settings very limited. Ultramon allows for complete customization of resolutions, icons wallpapers and screen savers. As well as loads of other stuff :D
