Dual Monitors (TV & PC)
5 Apr 2006
Is it possible to have dual monitors with a TV & a PC monitor?
I have a 22" TV which has HDMI output and an Acer PC monitor which is VGA only, I want to use them at the same time but don't know if that's possible.
just connect the cables and turn both on
on the desktop you can right click and go to nvidia properties and you should see both monitors and be able to set resolutions etc.
I have the PC monitor connected via DVI and the TV monitor connected via HDMI, the TV isn't be found but the PC monitor works fine, any idea's?
I have an Acer X201W PC monitor and Acoustic Solutions LCDW22HD TV monitor
