Dual Monitors
7 Dec 2009
I thinking about setting up Dual Monitors (extended desktop)on my pc, I have the asus ati 5850 video card with 1 dvi and 1 hdmi port.
do I need another video card or some other adapter to do this.
thanks
Nope, no special cards or cables needed.
However, I think the HDMI and the 2nd DVI are the same, so plug it into DVI-1 and HDMI. Read the manual it tells you properly.
I run 2 mixed screens this way. Eyefinity needs another adapter, and 2 identical resolution monitors.
Never knew that Philly ! Nvidia card here anyway. lol!
I think I will be buying 2 identical Monitors they both have dvi and hdmi on then to.
so should I buy Eyefinity adapter?
