Dual OS - have I Broken It?
31 May 2007
Hi,
Partioned my drive using XP disc and the installed Vista Business onto the larger partion - all went ok. Then used Acronis to restore an XP Pro image to the smaller partion - now when I turn on it loads straight into XP but hangs at the welcome screen.:confused:
Have I done this completely wrong are is there something I can do to get this working again?
Thanks
you do
Vista uses a new bootloader.
XP uses the old version thats not compatible with vista. When you install XP over the top of vista it replaces the bootloader that comes with vista, with the old XP one.
as a result the XP bootloader cant boot Vista
Install XP then Vista ....
as for how you get it back ? http://support.microsoft.com/kb/919529
