Dual Pane Explorer
20 Mar 2005
Leicester
Im looking for a decent dual pane windows explorer. Would prefer free but dont mind paying if its good as it will be used a lot.
Had a look thru the freeware thread but couldnt really see what I was after so am looking for suggestions and recommendations please
thanks in advance
PS Im running windows7 so needs to be compatible please :)
I'd recommend Directory Opus which is a paid-for solution. It's absolutely awesome and will do everything you ever want to do with files. There's a free trial available - have a go!
cheers will have a look
EDIT : have given it a bash and am impressed, going to use the 60 day evaluation to see if its worth the £41 or not
I notice that explorer in W7 is dis improved over Xp. Navigating in the right pane is not reflected in the left. Also free space is not reported for HD in the status bar at the bottom. Maybe theres a way around these I dunno.
