- 6 Jan 2013
- Rollergirl
I've got a dual pump configuration:
Res > Pump > 480 Rad > 240 Rad > 560 Rad > Res > Pump > GPU > CPU > 240 Rad
One of the pumps started making a strange noise:
So I tried to adjust speed and then finally rebooted PC and the noise went away. About an hour later, and I do not exaggerate here, there was a sound like a sander being used somewhere in the distance. It turned out to be the pump again:
I'm in the process of replacing the bust pump, but I'm wondering if my loop configuration has caused it to fail? I ran the bust pump at 100% constantly and I ran the other pump at 20%. This is because the 100% pump is in another room (garage) and it means all the noise and heat is in there.
Should I run both pumps at the same (lower) speed?
Are pumps designed to run 100% 24/7?
(though I don't usually say literally when it's implied).
