Hi all,
I am looking to upgrade my PC to Dual monitors (have gotten too accustomed to them at work!) which graphics card do you recommend? I would also be doing 'some' gaming but I wouldnt be doing this dual screen I would just use a single screen for this.
Was thinking about a gtx460 - would I see better performace with the 2GB model seeing as this will be a dual screen setup?
My MB is Gigabyte GA-880GA-UD3H 880GA Socket AM3 8 Channel Audio ATX Motherboard.
budget is around £100-£200.
Cheers
Scotlad
Cheers
Scotlad
