Dual screen issues
3 Jul 2008
Fife way up in Scotland
Looking for a wee bit of advice here. just set up my dual monitors. having no issues other than trying to run multimon and ultramon, both say theres issues with my system in runing it. any ideas?
ultramon is an excellent program,
Have never had any issues with it,
Are you sure you have the display set to say 2 x 1024x768 displays rather than a single span of 2048x768? for example?
Otherwise what error messages are you getting?
I have a feeling this is exactly what the issue is. i cant check just now at work but im 100% sure it is now i think of it. Head in hands duh clown fish here.
Cheers, if one thing i have learned on ocUK forums is how to make a damn fool of myself cheers. will go change it when i get in
lol no worries matey,
If its not that try to get the exact error message if it displays one, also what gfx card you are using and drivers.
Let us know how ya get on.
Using an 8800GT 512mb, runs tickity boo just cant get it to work with these applications. primarily want it for spliting things on my task bar so it shows on that screen what is runing, if that makes sence,
I also tried to remove something from add/remove programs and it said i was in safe mode or windows instal wasnt installed correctly. i was on a standard boot and re installed windows instaler. i feel the issue is how i have put above with having the span streached over the two minitors.
