Man of Honour
- 15 Nov 2006
- Hull
Hi folks
Appreciate some advice on my intended dual screen setup. I currently have a Viewsonic VA1912w 19" widescreen TFT, and am looking into the possibility of adding another one.
I had assumed that the model OcUK stocks was identical to mine, but it seems that Viewsonic have 'refined' it a little in the meantime, removing the DVI input, leaving only the VGA (the newer screens are officially called the VA1912w-2).
My video card has dual DVI out, but I can use a converter no problem for the new screen. My big concern is that the picture will not look identical, since one is using the VGA and the other DVI. I wondered if anyone with a similar setup could confirm this for me (or otherwise!)
Cheers,
FK
Cheers,
FK
