Dual Screen question
20 May 2006
If your playing a game in full screen mode, is it possible to choose what screen you want to play it on. Without changing the primary monitor?
If your on xp and go into control panel, appearance and themes you can change the monitor from there but i think you said you dont want to do that..
Thats all i can think of.
a very few games let you choose a screen to run on, but not many - the performance can take a dive on the non-primary display also. you could try ultramon. that might be able to shift as you want, not sure tho.
