Just wondered if anyone could shed any light on this problem one of my colleagues is having.
- E6650 @ 2.33Ghz,
- 2gb Ram,
- Radeon HD 2400 Pro.
- 2 x 'Hanns-G' 19" LCD monitors.
He extends his desktop across both monitors with a splitter cable (both running at 1280x1024 )but all of a sudden, the primary screen viewable area is displaying only 1024x768 of the resolution expected. i.e. you can scroll off screen & the desktop scrolls to the 1280 resolution.
I thought this "virtual desktop" type view was when you set windows to a resolution higher than the screen could take. When you look in display manager, the resolution is set correctly.
After looking for a software setting to force this view (found none!) I swapped the cables to prove it was not the screens.
Any ideas? I'm thinking reinstall video drivers?
Thanks
Dan
- E6650 @ 2.33Ghz,
- 2gb Ram,
Thanks
Dan
