dual screen with laptop
25 Jan 2003
UK
Hi all,
Wondering if any one can help me with this, I am currently using my laptop as my main rig, untill I can afford a new computer, got my nice big dell monitor attached.
My Question is can you dual screen with a laptop, but make the laptop screen 2?
Been trying for a few days, with diffrent programs and diffrent settings, but just cant seem to make the lappy the secound screen. The idea was I wanted to use my dell for games/dvd's, and be able to use the laptop screen for web!
Any way any help you can give!
many thanks
Mark
Are you using XP? If so go:
Display Properties ->Settings ->Advanced Tab ->Displays
Then set the TFT to 1 and the laptop monitor to 2. This should do what you want...
Thanks for the reply, this was on eof the first things I tried, the option to do this is grayed out, so you cant switch the monitor numbers!
Yeah I can extend the screen, onto both monitors, but I can not set my non-laptop monitor to monitor 1 if the laptop monitor is being used. The tick box if always greyed out.
can you select the option "make this monitor my primary something-something"? for the TFT.
my laptop can do this (intel GMA950)
It can be done with ATI cards! I have it working with my mobility 9700 using omega drivers. For better configeration options i would recomend using ultramon :D
