Dual screens with different resolutions issue.
23 May 2011
I currently have a 1920x1200 monitor and a 1680x1050 monitor setup and when trying to move my mouse from the larger monitor to the smaller one the mouse is stopped if I try doing it over the top inch and a half or so. This is an annoyance it it often ends with me closing a program I don't mean to close. Is there a way to stop this from happening or is it an inherent problem of using two different res monitors?
Thanks.
Not sure if this is the easiest way but if you download 'Display Fusion' go settings<window management then tick the box for "Prevent mouse cursor from snagging on unaligned monitor edges"
Again not sure if its the easiest way but as I use this program anyway its how i do it. Or just buy matching res monitors.
