Dual screens.
9 Oct 2008
Somerset, UK
Hi i am using at 19" 1440x900 screen and a 18.5" 1360x768 screen. Just wondering if you can name any good software for dual screens thanks.
Having never used Display Fusion I don't know what It can and can't do, but from a quick google image search it doesn't look like it gives you a task bar on the 2nd screen like Ultramon does.
N.B I use ultramon on XP, not sure how it handels Vista X64. There is a version that says its compatible though.
I think ultramon might be the most worthwhile bit of software ive ever spent money on.
I use ultramon on Vista x64. Only really use it to have the 2nd task bar and for spanned backgrounds.
Another vote for unltramon, good for wallpaper, second taskbar, and switching applications from one screen to the other with one click.
