- 8 Jan 2007
Hi,
Bit of a weird one here on "ranked" memory settings.
Basically I have:
GA-Z170-Gaming K3
16Gb Corsair Vengeance PC3000 Ram
All working fine no issues etc. Then I decided to upgrade the existing 2x 8Gb SPD's to 2 more - so now I have 4x 8Gb PC3000 rams - I checked they were exactly the same model before installing etc.
All boots / loads & doesnt appear to be any issues; however , strangely, on CPUID if I go to the DIMMS 2/4 (new sticks) it says their "ranks" are single, whereas the others are dual.
I know ranks is different to the dual-channel memory setting, but i didnt know of any reason why these settings would be different & also the fact they are working with different settings.
Anyone had this before?
Cheers
Basically I have:
GA-Z170-Gaming K3
Cheers
