Evening all, I'm just embarking on my first proper watercooling build, although I've been building PCs for years. I wanted some advice on the watercooling bits and pieces I'm thinking about getting.
As far as components go, I'm going with a 3770K, an Asus P88Z mobo, 32Gb DDR3 2400 RAM and a 480Gb SSD, along with the 2 EVGA superclocked Titans. Those bits I'm fine with, but I'm not too sure whether the loop I'm thinking about is man enough for the job.
The case I want to use is a Shinobi XL, reservoir/pump combo is the XSPC Twin D5, 2 Black ICE SRI radiators, a 240mm and 360mm, 5 Scythe Gentle Typhoon fans, an EK supremacy CPU waterblock, 2 EK-FC Titan blocks, and the EK PSC compression fittings with XSPC 3/8" hose to connect them all.
I am thinking of running from the D5 combo to the CPU, from there to the 240mm radiator, then from there to the GPUs, then to the 360mm radiator, and back to the reservoir. Does that sound like the best way to do it?
Thanks in advance for any help you guys can offer, there appears to be a LOT of experience in here!
