Dual VGA card
20 May 2014
Hi Guys,
I was wondering whether anyone could give me a quick bit of advice.
I had a 4850HD which decided to die on me, so for the moment im using my old Gt 220 card. My problem is that i have two monitors and both of them only take VGA, and im struggling to find a reasonable card that will output to them. I dont really do much gaming so im not looking for anything amazing.
I did try buying a 7770HD but that didnt work.
My budget is only about £60.
The only one i have found that appears to work is a Gt 630, but from reading the reviews its apparently pants.
Could anyone point me in the right direction.
Thanks in advance
Matt
You could look at getting any with a dual DVI output and buy some DVI-VGA adapters. Used to be standard things in boxes, but don't think that's the case anymore.
Thanks for the advice. I have a couple of those adapters at home already which is good. Am I right in thinking I need to get dvi-i rather that dvi-d
Do you have any cards in mind for my price range
Cheers
