Hi Guys
Title says it all. The Ducky legend looks spectacular. Stock arriving tomorrow!
As you would expect, OcUK are the first in the UK to list the Legend
Ducky Legend Mechanical Keyboard, Blue LED, Red Cherry MX Switch Silver Aluminium Top - UK Layout @ £129.95 inc VAT
Ducky Legend uses 5mm thick aluminum case top design for the most solid keyboard in the industry. The bead blast finished aluminum top is has a modern industrial look that is suitable on your desk for work or gaming. Ducky Legend is powered by an ARM architecture micro-controller and uses the most reliable Cherry switches. Even the PCB is dual layer construction to ensure the keyboard will work for years on end. The backlighting effects feature our most popular Reactive Mode, as well as User Customizable Zone backlighting, and our newest Explosion Mode. These backlighting effects give you a great keyboard to look at in addition to being a keyboard you can rely on.
Features:
Anti-Ghosting key matrix:
Ducky Legend can accept any key combinations without ghosting or key blocking. In addition, the keyboard can be switched to full USB N-Key Rollover mode that accept as many simultaneous inputs as you want.
1000Hz report rate:
The keyboard sends update of the keyboard's status to the computer every 1 millisecond. This minimize the time from when the key is actuated and the computer receiving the signal, giving you a lag free performance.
Windows key lock function:
To prevent accidental key press interrupting your gaming session, the Windows key can be easily disabled with 2 key presses. Don't let stray key presses ruin your day again.
USB Repeat Acceleration:
Ducky brings adjustable repeat rate and repeat delay to USB keyboards. You can fine tune the repeat rate and repeat delay for gaming or your specific applications.
Note: USB Acceleration may work differently in different applications. Please use a suitable setting accordingly.
Specification:
Dimensions: 458 x 36.5 x 155 mm (W x H x D)
Weight: 1.47 kg
Color: Silver
Keys: Cherry MX Red (mechanical)
Release pressure: 45g
Release Height: 2 mm (4 mm to the ground)
Layout: UK ISO
LED lighting: Blue
LED modes: 100%, 0%, Breathing, LED Zone Customization, Reactive, explosion)
Connectivity: USB 2.0
USB polling rate: 1.000 Hz (adjustable)
Compatibility: Windows XP, Vista, 7, 8
Scope of delivery:
Grey WASD keys
Keycap pliers
Only £129.95 inc VAT.
ORDER NOW
Ducky Legend Mechanical Keyboard White LED Red Cherry MX Switch Black Aluminium Top - UK Layout @ £129.95 inc VAT
Features:
1000Hz report rate:
Specification:
Weight: 1.47 kg
Color: Black
Layout: UK ISO
LED lighting: White
Scope of delivery:
Grey WASD keys
Keycap pliers
ORDER NOW
Features:
1000Hz report rate:
Specification:
Weight: 1.47 kg
Color: Silver
Layout: UK ISO
LED lighting: Blue
Scope of delivery:
Grey WASD keys
Keycap pliers
ORDER NOW
Features:
1000Hz report rate:
Specification:
Weight: 1.47 kg
Color: Black
Layout: UK ISO
LED lighting: White
Scope of delivery:
Grey WASD keys
Keycap pliers
ORDER NOW
