- 27 Mar 2004
- England
Well, just to inform you that I still cannot locate an air hose/ducting for the air box. I went to three places yesterday, none seem to have 2.5" just 4 inch plus!
About 240 miles to 30 quid. Round town mileage as thats what I used to only do.
mostly slow with odd thrashing & was better with stock filter.
At eg 98.9 Ltr thats 35mpg I thinx (4.54L / gal) , which sounds good.
I get 28mpg with mainly short journeys round townmostly slow with odd thrashing & was better with stock filter.
Only get 23mpg with normal UL so I use S/UL which works out cheaper![]()
A bit off topic but...
Which would you recommend:
K&N Panel filter + Drilled airbox (cheaper)
K&N Induction kit (more expensive)
Ive read that induction kits can actualy decrease performance and im better off with a panel filter but my spidey senses tell me otherwise.
Your opinions please![]()
depends on the car. Fiestas for instance generally loose power with a Induction kit due to heat soak. Panel filter in standard box is best, as the standard box gets a good cool air (although its ontop of the engine itself)
the ST version of the fiesta kinda sucks though, its got a very long airfeed with lots of 90degree bends, so the induction kit is good on that simply because your removing all those bends.
every car is different, probably best to say what car it is, and maybe post on a owners club forum too?
