it arrived at 2pm
it is new £1600
quite a basic spec stayed with the stock selections for 90% of the lappy i upgraded the graphic card to the radeon hd6990 and also went for the killer network card also got the 1920x1080 wled screen (not the 3d one) am a bit dissapointed that i stuck with the stock hard drive, i figured it will be cheaper to do that upgrade myself.
box contents were all in order except they do not give you the leather bound used manuals anymore which is abit tight of them considering how much the machines cost.
overall am a happy bunny![]()
the graphic card is awesome so far, however the lappy gets abit hot so am ordering myself a coolermaster notepal u3 from play for £17...nice buy
i am now in need of a guide though.....if i buy an ssd drive how do i make that the master and install all the stuff that already on the other drive?
disks i got with machine are :-
alienware m17xr3 resource cd
alienware windows 7 cd
and 2 other none important disk's
I have always done a fresh install from the disks. If you clone an SSD does it align the partition correctly?
Will be throwing an SSD in mine when it arrives
I have spare dell media
If you need a copy give me a shout
