Hey guys,
I'm having some problems with my two new Dell U2515H - I presume its an AMD issue with my R290.
When I use them as dual monitors, after a while, they both start synchronized flickering, and I'm completely clueless how to stop it. However if I'm only using one of them, it's completely fine.
The cables are in firmly, and if I revert to a single monitor setup during the flickering, it stops. Also if I restart my PC, it stops. I've tried adjusting the video card memory clock speed above 1250 MHz, but then both monitors turn off, and even if I restart my PC, then monitors turn off a few seconds after booting back to desktop.
I'm using an AMD R290, connected via MiniDP (primary) and HDMI (secondary) at 1440p 60Hz.
I took a video for you to look at, if you could help me out pleaseee: https://youtu.be/j86X2aPpY6U
EDIT: Also after a while, when experiencing these visual artifacts, they eventually disappear.
Thanks!
Thanks!
