Right so built a PC for a friend with a collection of new and 18 month old parts. He has 2 PCs next to each other connected to a KVM switch that connects to 2 monitors.
Before this build everything was VGA, so 2 PCs both output 2 lots of VGA signal to the KVM switch (4 VGA inputs total) which then outputs 2 lots of VGA to the 2 monitors.
New PC has an Powercolor Radeon HD 5450 which has VGA, DVI and HDMI out. He is able to use the VGA connection to output to 1 of the monitors but using DVI to VGA converters does not output to the second monitor.
I've ready this is because the card (and most cards) can only output 1 lot of analogue at once.
What is the cheapest way round this, replacing the KVM switch with a 4 port DVI one would cost about £100 and then he would also have to upgrade his other PC.
Can you get graphics cards with 2 VGA outputs?
What about using the 5450's VGA and a USB to VGA output - would that work?
Can you buy special powered converter boxes that will actually change the signal to VGA as I understand a DVI to VGA adaptor just changes the connection and not the signal.
How about something like this:
Search for 'HDMI to VGA Audio Video Converter 1080P - UK Plug' on the rain forest site.
