My g/fs pug 405 has the battery light on dim, occasionally. I suspect duff alternator.
I told her to go to the local Hi-Q place on the way home, they just said, yeah knackered alternator, new one is £170 fitted which isn't bad as a new one is £100+vat from GSF. They didn't do any testing, which I think is a bit poor, surely it could be the battery on the way out? The did check the belt for tightness and said its not that. Just let them do it for an easy life?
