Dumb ex Windows Person needs help
30 Jul 2004
Auckland
Hi, not sure if anyone could spare a moment to educate me on something. I have been using linux for umm two days (Ubuntu 10.04) and decided I would try installing PlaneShift.
Worked out after a quick google the chmod command, then that I needed to install it to my user account etc. But when I try and run the game I just get an error and can't locate any help online as to why. The uninstaller works fine but nothing happens when I try running the client from the desktop. I dropped to Terminal and get the following:
beren@ubuntu:~/Downloads/games/opt/PlaneShift$ ls
art guide psclient pslaunch support updaterinfo.xml
data lang psclient.bin pslaunch.bin uninstall vfs.cfg
docs libs psclient.cfg pslaunch.cfg unscript.sh
beren@ubuntu:~/Downloads/games/opt/PlaneShift$ ./psclient
Inconsistency detected by ld.so: dl-close.c: 731: _dl_close: Assertion `map->l_init_called' failed!
Could anyone tell me what this means and how I fix it?
Grr ok so I was being a real dumb user and not running the .bin file. Now getting another error about shared libraries... and I can't seem to find the file other people are running to fix the problem. Meh, I'll get there eventually ;)
/edit and thanks for the suggestion Sirius... but you under estimated how dumb/lazy an ex Windows user can be!
/edit2 Now yet another error... ho hum.
not sure if it'll help, but you can use "ldd" to list the shared libraries needed by a program/library.
ldd <item>
