(Dumb) Gpu-Z ?
31 Oct 2007
Gods County(Allegedly)
I note that there appear to be 2 Gpu Temperature readings :-
First is stated to be the Gpu temp. as reported by the graphics driver.
Second is stated to be the temp. as reported by the ADT7473 sensor chip.
Are they reporting different areas/parts of the gpu ? Or are they reporting the same?
If it's the same would like it to be the sensor chip one as it reads 3/4c less all the time:D
If this is a dumb ? , my apologies - been running gpu-z for a few years and never noticed before:o
GPUZ can read the core temp, memory temp and a few other temps such as the VDDC. If you google GPUZ with your card you should be able to know exactly what the temps are.
