Dumb question alert
16 Sep 2005
What used to be a UK
Is there a way to send an image with a text message from the iphone to an individual's email?
sure go into your photo library and select the photo you want and click email photo. You can add text above the photo if you wish.
Brilliant! Thanks for that Will 3rd. I wanted to make a complaint showing some documentry photographic evidence and thought it might be easier to use the Iphone as oposed to the pc as the photo was taken on the Iphone.
