dumb question re HIS Excalibur ATI Radeon X1800XT/512MB/GDDR3
21 Oct 2002
Sol System
ok its new video card time . thing is i am running a 22" crt Mitsubishi diamond plus 200. This monitor has 2 connections for D-Sub so i can run 2 PC`s from it .
However i notice a lot of new video cards come with 2 dvi outputs and no d-sub.
Am i correct in thinking that they wont be compatible with my monitor as it doesnt have dvi connector or does the dvi at the cards end connect to a dsub at the monitor via some sort of dongle/adaptor ?
cheers
The DVI ports on the card are DVI-I ports. That is, they contain both an analogue and a digital signal
The card should come with DVI-I to D-SUB converters so you can use your current monitors with the card
Stupido said:
thank you for the reply .now i just have to decide between 1900gt and 1800xt .
cheers
Yup which is why i said x1800 XT see here, and linked to a review that shows the x1800 XT outperforming the x1900 GT, Cyber-Mav its time for a visit to specsavers. :D
