Dumb Question - which edge connector for SLI?
12 Dec 2005
This is my first SLI configuration. I've bought a pair of GTX 980 cards and each has two edge connectors where I could, possibly, connect the SLI bridge. Which one should I use, or doesn't it matter?
Thanks in advance for any help.
OK, thanks. That's the one I've used.
The manual is very unclear. In one diagram it points to the connector furthest from the brackets and in the other diagram it points to the connectors closest to the brackets. We'll see when I finish the build and try powering it on ;-)
